Reproductor de tarjetas SD de altas prestaciones
En EBay venden el siguiente sustituto de transporte de CD:
http://cgi.ebay.es/ws/eBayISAPI.dll?ViewItem&item=200422021423&ssPageName=ADME:B:SS:ES:1123
Aseguran que tiene altas prestaciones, os paso la información de dicha página y ya diréis lo que os parece (Lo que está claro es que es absolutamente silencioso):
QLS QA-550 AUDIOPHILE REMOTE SD WAV TRANSPORT PLAYER CD
Estado del artículo: New
The QLS QA-550 remote digital WAV transport is designed from the ground up to be a very high-end audiophile audio playback solution.
UK Stock!!
Forget your old, bulky and fragile CD transport / player, which is based on technology that is over 20 year old.
No matter what the quality of your CD transport / player is, its probably not going to come close to offering the same performance as this compact, futuristic little gadget.
Utilising cheap and widely available SD memory cards that can each store up to 16gb of uncompressed WAV files, the CD is a thing of the past.
The ideal CD transport is not a CD transport, its one of these WAV SD transports.
Reasons why the QA-550 is better than a traditional CD transport:
* No moving parts to wear out. Consistant performance every time!
* Won't suffer from stability issues caused by dust, dirt or smoke
* No reason to take your valueble CDs out of their cases each time you want to listen
* WAV files are error corrected so don't need real time error correction unlike CDs
* Far less jitter than most CD transports / players, even very pricey ones. Sounds better
* Totally resistant to vibrations. No skipping nor any need to keep on expensive hifi rack
* High Accuracy system clock ensures jitter level is miniscule
* Whole box sets of your favourite CD music collections can be captured in glorious, uncompressed WAV format onto a tiny SD card no bigger than a postage stamp!
* Can be used to play music for extended periods for equipment "burn ins". No mechanical parts such as lasers or motors to wear out
About WAVs
WAV files are the favourite format choice of people who can't bear the sonic difficiencies of the lossy compressed MP3 format yet want to store, preserve and playback treasured CD collections from their computer hard disk drives.
Up until now, these people would simply be content to use their computer as their main hifi source component.
Whilst excellent at converting CDs to WAV files, the PC / Mac is still not the ideal music plackback device. The majority if PCs don't have the best powersupplies and are absolutly packed with noisy, interference inducing components.
Multiple noisy fans buzz away constantly and due to components fighting over limited resources, "pops" and stutters on the audio are not uncommon.
In these days of hugely expensive utility bills, the electricity consumed in putting a computer to use for considerable periods just for music playback is also quite considerable as is wear and tear to the hardisks.
Reasons why the QA-550 is a better music transport than a PC
* Silent ( no moving parts )
* powered by dedicated 9v dc linear power supply. Helps reduce jitter
* No pops stutters or audio glitches (assuming that WAVs were extracted with love by EAC)
* Uses nowhere near the amount of energy that a PC needs
* Far more compact than even the smallest laptop PC
* Useful remote control functionality
Comes complete with:
* 2gb SD Card
* USB2 SD Card Reader / Writer
* User Manual
* 9v DC power supply
* Remote control
Specifications
· Player for 44.1kHz/16bit WAV file.
· Main CPU use PIC 16bit MCU,( Supports future software upgrades)
· Support for up to 55 folder, up to 550 music tracks
· Remote control supports folders up (+1) or folders down (-1). It also allows direct track numbers to be entered (You can input 1bit(1-9)or 2bit(10-99) or 3bit(100-550).
· Supports both FAT16 and FAT32
· Supports most types of SD memory cards (SD / SDHC 1Gb-16Gb.
· Firmware update file download: http://www.qlshifi.com/en/Download.htm
· Short signal path
· Precision Clock: 4 pin high accuracy crystal clock 2ppm 11.2896Mhz TCXO.
· Jitter: The use of a low-jitter clock and power driver circuit ensures clean and stable clock signal.
· Uses high-quality components: Sanyo OS-CON capacity, AMS1117-3.3, MC7805, 74VHC04, CS8405....
· Power: 9v DC.12v batteries can also be used
· Stylish aluminium case
· Output Interface:
Digital Coaxial 75 ohms RCA, Optical Toslink, I2S output pads available on PCB (advanced users only.Voids Warranty!)
· Size:
Case only:8.1cm x 2.4cm x 13.5cm (width x high x deep)
· Weight:
Main unit only:230g
Package:750g (Include Power supply)
The QLS QA-550 is a digital transport and needs to be partnered with a DAC (Digital to Analogue Converter) to playback music in a HIFI system
Any questions welcome.
Happy Bidding!!
UK Stock!!
About WAVs
* 2gb SD Card
* User Manual
* Remote control
Specifications
· Short signal path
· Output Interface:
· Size:
· Weight:
Main unit only:230g
Happy Bidding!!
clonix- Cantidad de envíos : 238
Re: Reproductor de tarjetas SD de altas prestaciones
Ah se me olvidaba: una tarjeta SD de 16 GB sale por unos 36 €
Saludos a todos
Saludos a todos
alguien ha probado ese invento!!!
salu2
salu2
Hola,yo tengo una grabadora profesional Edirol(Roland)r09(creo)y graba sobre Sd hasta 24 bits/48khz.He pasado algunos vinilos por ejemplo y el resultado ha sido fantastico.Un saludo
Localización : ALICANTE
Me parece muy poco interesante.
Realmente hace falta un aparato con capacidad para grabación en HD (192KHz, 24 bits).
Este nuevo Nagra si parece ser algo especial! el problema es siempre el mismo, el precio......
http://www.avguide.com/product/nagra/nagra-lb?src=Playback
Carlos Suarez
Carlos Suarez
CArlos Suarez Ascaso- Cantidad de envíos : 443
Carlos :¿ qué quiere decir en éste caso HD ?
Localización : LA-RE-DO
Pues en alta definición, grabar desde 44 a 192 khz, con salidas balanceadas, memoria interna, a baterias o red, memoria flash, SD cards, display en color, etc..Debe costar entre 2 y 3000 euros y le da mil vueltas a cualquier transporte convencional, en fin a ver si con la loteria del Niño......
Es importante oir y contrastar y tambien no comprar cacharros que no dan la talla y luego te cansas porque no valen para nada.
CArlos Suarez
CArlos Suarez
¿Tú crees que 24/192 es alta definición?
Por lo visto la definición no tiene que ver nada con ésto.
La definición del cd es perfecta en cuanto a la teoría , otra cosa será la implementación de los circuitos.
Pero hoy día parece estar bastante logrado.
Rubius, te adjunto las especificaciones del Nagra para que veas lo que quiero decir:
Es capaz de grabar en tarjetas SD con muy alta calidad, es un aparato robusto y estamos hablando de 2-3.000 euros que sí que es caro pero es para toda la vida......
Recording
Internal storage 2 GB NAND Flash memory
Removable media Compact Flash type II / III (Hot Swappable)
Disk format FAT 16 / 32
Recording Method Linear digital PCM, MPEG 1 layer 2 or MP-3
File type 16 / 24 bit Broadcast Wave File BWF (WAV)
A/D & D/A conversion 24 Bit Sigma Delta
Bit rates 32 kbits/s up to 384 kbits/sec
Tracks 2 individual
Sampling Rate 44.1, 48 kHz, 88.2, 96 and 192kHz
Recording capacity 1hr 24 bit 48 kHz per GB of disk / memory
Pre-recording buffer Programmable (Maximum 3 seconds)
Display 2 x Colour LCD
Level meters On colour display AND by LED
Inputs
Digital input XLR 3-pole
Analogue inputs
2 x XLR Microphone (Dynamic, +48V Phantom) / line
Microphone input sensitivity 2 and 15 mV/Pa selectable
Limiters On microphone inputs
Line input sensitivity Adjustable from -6 dBm up to +24 dBm for 0 dBFS recording
THD at 1 kHz <0.1% Mic, <0.01% line (measured on AES out)
Frequency response Mic, 10Hz - 48 kHz ± 0.5 dB, Line ±0.2 dB (measured on AES out)
Signal-to-noise ratio >100 dB
Input level adjustment range 50 dB Mic and from -6 to +24 dB Line
Input filters LFA (with vortex filtering)
Internal microphone Electret on the front panel
Outputs
Analogue line output XLR 4.4V max (+15 dBm)
Digital output XLR AES-3 (24 bit or 16 bit)
Headphones Stereo 6.3mm (¼”) Jack 50 Ω
Internal speaker 0.2W
Other
USB Host USB 2.0 connector type "A"
USB Device USB 2.0 connector type "B"
M/S Decoder Switchable
Ethernet RJ 45
General
Dimensions 175 x 65 x 185mm (W x H x D) (Incl. battery box)
Weight 1.4 kg (3 lbs) (Incl. batteries)
Power supply External 9 - 15V
Power Consumption Approximately 2W (160mA on 12V)
Charge time Approximately 3 hours (with NimH cells)
Battery life
8 hours (8 x NiMh 2500 mAh) Record @ 24 bits 48 kHz with 2 x phantom +48V (2 x 4 mA), continuous recording. Between 5 and 5 1/2 hours with 8 x LR6
dry alkaline cells.
CArlos SUarez
Recording
Tracks 2 individual
Inputs
Analogue inputs
Outputs
Other
Ethernet RJ 45
General
Battery life
dry alkaline cells.
CArlos SUarez
Pues chulo sí que es.
La estética de Nagra me gusta bastante , pero el precio me corta.
CArlos Suarez Ascaso escribió:Pues en alta definición, grabar desde 44 a 192 khz, con salidas balanceadas, memoria interna, a baterias o red, memoria flash, SD cards, display en color, etc..Debe costar entre 2 y 3000 euros y le da mil vueltas a cualquier transporte convencional, en fin a ver si con la loteria del Niño......
CArlos Suarez
Si crees que lo de las salidas balanceadas, la memoria interna, batería/red o el display tienen que ver con la ALTA DEFINICIÓN!... juler!.
Yo todavía no conozco aparato (de audio o no) que lleve disco duro que sea "de fiar"; y si crees que por ser Nagra la cosa va a ser diferente (me parece que Nagra no hace HDs ).
Y respecto a lo de asociar "dar la talla" con "fiabilidad"... si quieres hablamos de los SACD de Marantz, los "altos" de gama (creo que era el 11 o el 15); en Mundo-Hifi varios tuvieron problemas! y no eran baratitos precisamente.
Y de los precios de Nagra, uuffffff !!; a veces pienso: "...¿no será un error de imprenta y habrán puesto un numerito de más?!...".
Comprendo que la gente asocie la palabra Alta Definición a lo que nos enseña el marketing del video y la imagen.
Lamento haber usado esa palabra para el audio, solo pretendia decir que un buen equipo de audio (como el NAgra en este caso) sea capaz de extraer de forma maravillosa MUCHA INFORMACION de una simple tarjeta SD ( yo lo he escuchado en LOndres en casa de un amigo).
Prometo no volver a usar esa palabra nunca mas en este foro, debe estar dedicada al Full 1080 y antes de acabar el año me confesaré.........
Feliz año
SAludos
CArlos Suarez
Feliz año
SAludos
CArlos Suarez
La idea de esta tarjeta es sustituir al transporte de CD sin más historias, y la publicidad dice que lo hace al nivel de los más prestigiosos. Es decir este aparatito en cuestión lee ficheros wav de la memoria SD y saca una señal digital PRACTICAMENTE LIBRE DE JITTER (según la publicidad) a 16Bits/44KHz que bien conducida por un cable que no incorpore jitter apreciable y bien tratada por un DAC dará una señal analógica de la máxima calidad.
Repito este dispositivo sustituye el transporte de CD y sis os fijáis tiene las mismas salidas que un transporte.
Se trataría de pasar a Wav los FLAC que nos bajamos de internet, con el EAC (sencillo) y copiar los ficheros obtenidos a carpetas de la tarjeta de memória SD o lo mismo partiendo del CD. Como en una tarjeta caben varios Cds y las tarjetas son muy pequeñas obtenemos un muy considerable ahorro de espacio. Sin embargo tendremos que seguir almacenando dichas tarjetas SD, a diferencia de si se pudiera usar un disco duro para nuestros ficheros. Por otro lado un disco duro tiene partes mecánicas en movimiento y hace su ruidito (en algunos casos bastante molesto) cosa que no ocurre con este sistema basado en tarjetas de memoria. Y recuerdo que el precio es muy bajo.
» Monitor para PC,prestaciones aconsejables.
» Equipos equivalentes en prestaciones al Rotel RCX-1500
» Se acabó la revista alta fidelidad
» Distorsión en frecuencias altas
» Fallos de Reproducción en las Altas Frecuencias
