Maravilloso ampli a precio ridículo, tal vez diseñado por Antonius (¿?)
+8
francisco martin diago
campo selice
pacohifi
RE-NOIR
LuxmanKing
Hamlet
12 participantes
Que alguien puje y que nos lo cuente:
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=120877686384&clk_rvr_id=324300500125#ht_928wt_1398&clk_rvr_id=324365320354&afsrc=1
Re: Maravilloso ampli a precio ridículo, tal vez diseñado por Antonius (¿?)
No me gusta. En un ampli de esta categoria le podrian haber puesto unas puntas de desacoplo (p.e. 4 chinchetas) por lo menos !!
LuxmanKing- Cantidad de envíos : 398
Lo que te pasa es que no te has leído las especificaciones técnicas. El diseñador promete un DAC en breve:
Welcome to the auction for my beloved Audio Stoat 01 integrated "amplifier."
Audio Stoat may be a new name to many, but in audiophile circles the name is already causing something of a rustle.
The "amplifier" is "carefully" hand built in rural Brittany, France by experienced artisans and the quality of this unit shines out from the crowd like a glimmering beacon of aural hope in a sea of audio detritus.
Lavishly constructed from a cardboard box the "amplifier" is veneered in a *prime finish which is usually 75pence extra over the normal price of the amplifier and, put quite simply, it exudes quality, luxury and exclusivity rarely seen in an amplifier at this price point.
In short every expense has been spared and no attention to detail has been taken, resulting in a true highish fidelity product with real pride of ownership value if you like that kind of thing. The "amplifier" is sure to take pride of place on the new owner's hi-fi rack!
Technical Gubbins
The "amplifier" boasts an enviable zero feedback circuit resulting in impressive zero distortion - not many hifi amplifiers on the market can boast figures as good as these!
Output would be a healthy 60w if it worked and the **BOS output "valves" are at least 50% guaranteed Morissons own brand, with markings still clearly visible on one of the tubes.
In its present configuration the amplifier boasts a huge zero watts per channel but can be reconfigured to deliver an even more impressive nowt in ***PPPPS configuration.
The "volume" knob is handcrafted using reclaimed materials which of course should ensure that the green credentials of this "amplifier" are beyond reproach and it is bolted onto the chassis so it turns and everything.
Inside the chassis everything has been left to chance and every component is of the very highest quality. High quality audiophile products such as a metal nut and bolt have been used.
*Packing Tape Brown
**Broken Old Stock
***Push Push Push Pull Shove
Anything made from the sale of this unique piece of hifi audio history over and above the postage costs will be given to a UK chariddy after payment has been received!
The Chariddy I have chosen doesn't seem overly bothered when i spoke to them, so I will choose another when the auction ends and send them the dosh. Suggestions welcome!
Audio Stoat have secured a world first review of the Audio Stoat 01 amplifier with Hifi Pig ("snoofling out what's hot in Hifi")
on the 1st of April
The unit has no plug and no attempt should be made to connect it to the mains or any other source of electricity as this will result in death if not something much worse!! Anyway plugging it in to anything would be downright stupid!!! Don't do it!!
We cannot guarantee that the "valves" won't be smashed to bits but we'll pack them as best we can.
COMING SOON -THE AUDIO STOAT DAC
Technical Gubbins
*Packing Tape Brown
**Broken Old Stock
on the 1st of April
a parte no le veo sentido a mezclar unas 300B y una 2A3, seguramente son sylavnia la de previo no se distingue bien...
en todo caso el que puje que nos diga que condensadores lleva y eso jejejej
Localización : Las Palmas
La de cachondos que hay sueltos por el mundo...
Yo ya he pujado por £0.01. Con mucha suerte, puede que me lo lleve. Me gustan las lámparas Philips vintage. Dan un sonido acojonante.
ampli
Se me viene una palabra "minimalista".
pacohifi- Cantidad de envíos : 158
Localización : el mundo
Fecha de inscripción : 30/11/2009
Tiene que dar un sonido ACAJANANTE
Quedan ocho días, lo consultaré con mi esposa porque no sé yo el factor WAF...
Supongo que la caja para el transporte se la ahorran no?
Localización : ALICANTE
campo selice escribió:Supongo que la caja para el transporte se la ahorran no?
No se supo. El vendedor solo dice esto:
Hamlet escribió:campo selice escribió:Supongo que la caja para el transporte se la ahorran no?
Que cachondos
Pues me da que el sonido sera algo brillante, .
francisco martin diago- Cantidad de envíos : 900
Si le hubiese puesto bombillas de bajo consumo melo pensaría.
Localización : toledo
RE-NOIR escribió:La de cachondos que hay sueltos por el mundo...
+1
XUANON13- Cantidad de envíos : 1219
Fecha de inscripción : 25/06/2010
que cachondos k sois CLARO k fue diseñado por mi ¿alguien lo dudaba? jajajajajaja
Creo que hay una versión con lámparas KT "bajo consumo" que suena de fábula......
elvis- Cantidad de envíos : 412
Localización : Somewhere over the rainbow
Si te ha gustado, el mismo ingeniero ha diseñado estas maravillas:
http://hifipig.com/the-mighty-audio-stoat-01-amplifier/
Rebombori tiene uno, os puede hablar de él.
Yo estoy esperando que salga el DAC.
» Quien necesite un ampli de válvulas a buen precio
» Ampli + DAC calidad/precio para unos Jamo S803?
» El "ridículo" Cervantes
» ODAC, el DAC USB diseñado por NwAvGuy
» Cables Ethernet de gama alta ... el colmo del ridículo!
