Crossover activo inline
Hola, me estoy planteando probar a usar unos "crossovers inline" para amplificacion activa.
Estaba pensando en concreto en estos:
http://www.hlabs.com/products/crossovers/index.htm
Sobre in-line crossovers: In-line crossover
Besides passive crossovers that operate on speaker-level signals and connect between your amp and your speaker components, there are also in-line crossovers that connect before the amplifier. They look like little cylinders with RCA connectors on each end and simply plug into your amplifier’s inputs. In-line crossovers make sure your amplifiers don’t waste energy amplifying signals you don’t want — like high frequencies to a subwoofer amp. Installing an in-line crossover is a great and inexpensive way to sharpen the sounds of your system, especially in a component speaker system.
F Mods
Examples of in-line crossovers
In-line crossovers each come set to a specific frequency and can’t be adjusted. Another disadvantage of using in-line crossovers is that they react differently to different amplifiers, possibly changing their crossover points unpredictably.
¿Alguien ha usado este tipo de crossover y quiere comentar su experiencia?
PS: por ahora no necesito consejos sobre minidsp, behringuers, jriver, accourate, marchand, etc, etc...
F Mods
despinos- Cantidad de envíos : 205
Localización : Malaga
» Crossover activo
» Crossover activo analógico para biamplificar
» Crossover/filtro pasivo a continuación de otro crossover/filtro pasivo
» Harbeth HL5 Crossover
» Crossover y fase
» Crossover y fase
