SOLILOQUY 5.3
SOLILOQUY 5.3
Buenas noches a todos .
Tengo posibilidad de comprar unas cajas acusticas
Soliloquy 5.3 ,en buen estado.
Tienen muy buena pinta. Ocurre que no puedo entrar
en la pagina web del fabricante.
www.solspeak.com. Solo en stereophile veo un analisis .
Gracias a todos
Gracias a todos
voyetrone- Cantidad de envíos : 28
Localización : SEVILLA
Fecha de inscripción : 20/11/2009
Re: SOLILOQUY 5.3
January 2000
@udiophilia.com continues its audition of the new 5.3 floorstanding loudspeaker from Soliloquy High Fidelity Loudspeaker Company
Anthony Kershaw
My introduction to the Soliloquy 5.3 loudspeaker was given under the auspices of Canadian distributor, Audiopath. The sound of the gorgeous-looking floorstanders was, as mentioned in last issue's sneak peak (http://www.audiophilia.com/hardware/sol53pt1.htm), "as clean as a whistle, with excellent dynamics and a tendency toward the spectacular". A further two months at home with them snuggled in my listening room did little to change my initial reaction.
The original design was developed by Dennis Had, owner of Cary Audio Design and designer of some of the finest amps this side of Nirvana. I am not privy to what precipitated Had's departure from the speaker world, but his loss was Bernie and Brock Byers' gain. As new owners, the brothers have taken Had's design and run with it, dishing up superb looking, excellent sounding high end speakers for what, in reality, are close to mid fi prices. With a new facility in Raleigh, North Carolina, it seems that Soliloquy intend to be here for the duration.
My preamble to this review mentions the specifications of the design and manufacturing excellence, both making for an easy load on my amplifiers and placing to rest the concern for the speaker's longevity. I should add that along with the easy loads, bi wiring, super cabinetwork, and the like, Soliloquy add a rear-mounted, three-inch port (metal, to reduce chuffing), document clearly and concisely, and offer a five year warranty. The company indicates a one hundred-hour break in period, with improvement up to the five hundred-hour mark! Serious auditioning took place well into the suggested period, the speakers sounding quite acceptable, if bass shy, right out of the box.
Associating with the Soliloquys were amps from ARC (D 125 - a powerhouse of blended technology), SimAudio (their Moon W3, a smaller but still classy cousin to the W5 behemoth), and the new Assemblage SET 300B from Sonic Frontiers' budget division, The Parts Connection (budget price, but not sound - full review forthcoming). The sound from old faithfuls like the Arcam Alpha 6 CD player and VPI Mk 3/Audioquest PT 7/Benz Glider combo justified their excellent reputations. The 5.3s were single wired with van den Hul cable.
Room placement proved embarrassingly easy. The speakers sounded fine placed without real attention to detail, sounding just that bit cleaner and deeper when room boundaries were aired out a little. Optimum placement in my asymmetrical listening space was three feet from the back walls and three feet from the side walls, with the boxes toed in approximately fifteen degrees. Soliloquy suggests 2/3 feet from boundaries and 10-30° toe in. A serious note: One must adhere to Soliloquy's suggestions when moving the 80lb enclosures and their respective spikes. An audiophile's foot (or worse) would never be the same without real care in the tweaking department.
Looking very much like kin to the ProAc 2.5, the 5.3's front drivers do a very creditable job in relaying musical information cleanly, with good bass attack, crystalline treble, and a pleasant midrange. With the Soliloquys' 90dB sensitivity, even the eight-watt Assemblage produced a full, rich tonal spectrum. The more powerful amps drove the easy load with absolute command and control, if without the finesse and neutral palette of the single ended Assemblage.
Coming after reviews of the exalted Verity Audio Fidelios and my superb reference Gallo Solo Nucleus (sadly discontinued, if the audiophile grapevine is to be believed), the 5.3s just about held their own and led me on some very musical journeys. After a particularly long stretch of listening, my thoughts wandered from pure musical essence to the exciting and visceral world of "hi fi". I noted this type of sound, not beloved in many audiophile circles, in my original assessment. The speakers boast music aplenty, but the voicing of the drivers does seem on the hotter side of neutrality. This led to larger than life presentations on varied source material from the chamber music of Mozart (Piano Quartets/Menuhin Festival Piano Quartet/Naxos 8.554274) to Reiner's magnificent Ein Heldenleben (CSO/RCA 09026-61494-2). All of this grandeur is not necessarily a bad thing. With the 5.3s, audiophiles can live on the wild side, and still have enough left over for most of their sensitive musical needs.
Piano recordings fared especially well. Naxos has given us rich and varied discography of late - masterful Rachmaninov from Idil Biret, stunning Dohnanyi from Marcus Pawlik and introspective Janacek from Thomas Hlawatsch. Though sourced from different producers and recorded in different acoustics, Naxos' house sound remained consistent on all three CDs, with bell-like treble, thunderingly clear bass, and middle octaves of decidedly rich tone. The Soliloquys did an admirable job in capturing and deciphering the complex lines of the three composers. Of the three, I have a great fondness for Janacek's music, and his piano works (used to great effect in Philip Kaufman's film masterpiece, The Unbearable Lightness of Being) are just as quirky, reflective, and chock-a-block with odd time signatures. Hlawatsch's performances are wonderful - his tone is lovely and the wistful nature of his interpretations match Janacek's mood. The subtle interplay between left and right hand was a pleasure and noticed distinctly through the 5.3s, also hinting at a slightly over zealous use of pedal. Very nice detail, here.
The old audiophile standby, The Buena Vista Social Club (Nonesuch 79478. Quite new, actually, but old in audiophile chronology), proved the Soliloquys adept at stage width and depth. Ry Cooder's Cuban crew whooped it up nightly for about a week. What a CD! I have heard this recording on many speakers (sounding best on Verity Audio Parsifals via Cary single ended amps), and while the Soliloquys did not match this combination, for thousands less, I got a wonderful sense of space and detail, with toe tapping rhythm all the way.
Strings, percussion, brass and woodwind sound varied in quality from recording to recording. Some turkeys remained while the great ones sounded true to their famous lineage. Athena's pressing of Rachmaninov's Symphonic Dances was terrific, with powerful whacks at the outset and the cramped quarters of the Dallas high school auditorium sounding quite claustrophobic. Instrumental timbre on this and other fine performances was good, but remained in third place when compared to the more expensive Nuclei and Fidelios. Imaging was good, too.
The singing voice was well characterized, with the tweeters sending off a little sibilance at times. Ian Bostridge and Bryn Terfel are two of this decade's finest vocal artists, able to convey the text in very emotional ways and never stretching the voice beyond their considerable talents. Bostridge's The English Songbook (EMI 7243 5 56830 2 1) and Terfel's The Vagabond (DG 445 946-2) were a great audition for the Soliloquys and the Assemblage SET 300B. Although the SET was unable to produce thunderous levels, this was by far my favorite combination (on both the 5.3s and Gallos, 90dB each, the Assemblage had problems when singers, sopranos especially, thumped out chest tone). However, this amp has increased my enjoyment of CDs tenfold. No hyperbole here. On lesser amps, Vagabond highlights some of the worst qualities of digital - harsh at times, quite uncouth if truth were told. The Assemblage was a superb match with the 5.3s (interestingly, Soliloquy's SM-2A3 monitor loudspeaker is especially voiced for SET amps of low wattage), with Malcolm Martineau's piano tone and Terfel's magnificent bass-baritone rich and harmonically truthful. On English Songbook, Bostridge's tenor voice rang true and clear. I heard him live recently in London singing Britten - he is an amazing and singular talent. This is the spirit I heard through the speakers, his voice brought through with natural ease.
Kudos, then, to Dennis Had for his vision and to the Byers for bringing it forth. The Soliloquys, a mere US$1895.00, are certainly among the finest at this price I have heard, with excellent range and dynamics, a banner sense of space and timing, good vocal/instrumental timbre and precise information retrieval. The Byers brothers have achieved what many consider the impossible: produce an elegant floorstanding speaker that sounds wonderful for a low price. They should most certainly be on your audition shortlist. As I said in the preamble: "at US$1895.00 a pair, the 5.3s must be regarded as one of the first audiophile bargains of the Millennium."
The Soliloquy Model 5.3 loudspeaker
US$1895.00 a pair
Distributed by Audiopath
9108 Yonge Street
Richmond Hill, Ontario
Anthony Kershaw
US$1895.00 a pair
9108 Yonge Street
